1 - 16 of 16 Posts
My SLK 230 1999 45000 miles has just failed its mot on emissions, gutted eh!! Anyway, the mechanic recommended that I change the LAMBDA sensor! Is this a hard job, where is it, how do I do it? Anyone got any pictures of the sensor being changed?
If you wish to PM (Private Message) someone, you need 15 posts. To get those 15 posts quickly, just go to the ‘new members introduce yourself here’ section and welcome enough new members listed to obtain your needed posts.
And finally, if you find something useful on your visit here today, perhaps something that saved you time or money, please consider becoming a donating member or make a one-time donation to offset development and operating costs. Even $5 is welcome! At the top of the page, click ‘Donate now’. Thanks!
Welcome from Michigan.....
Hello! My name is Nicole and I'm the proud owner of a 2004 SLK320 hartop convertable, black. I live in New Brunswick Canada. Hence the reason for a HARDTOP convertable for our winters. Hopefully I can contribute at some time down the line information for this forum. Feels good to be amongst other MB enthusiats.
Welcome from NW Blighty... :)
I'm not sure that your car will have a post-cat Lambda (O2) sensor. Wasn't common on UK spec cars at that time, Certainly wasn't mandated.
As for how difficult it is to change, the Lambda sensor looks a bit like a spark plug with a lead attached to it. The lead connects into the loom by plug/socket, so although many Lambda sensors are the same, the different part number call-up the cable and connector too. So it's important to get hold of the right part.
If you can get the car in the air, then it's usually a fairly straight forward job to do. I'd recommend disconnecting the cable first, then thread that through the correctly sized ring spanner. Best way to avoid rounding the nut.
1 - 16 of 16 Posts
