With the Keyless Go system can the car be programmed to recognize which of the two keys is being used....so that the respective seat settings for each driver will automatically come into play?
D
Guest
Used to be able to do that for both the SmartKey and the KeylessGo system but not anymore.
Each key can have custom settings but they have to be activated by hand
With our SLK in Bangkok once the key is inserted into the ignition the seat and mirror adjusts to that particular key.
But, with the SL the dealer said they have to do it for me. Once the key is used to open the door the seat and mirrors will adjust for that key. It does not work off the ignition.
D
Guest
Your SLK is a 2005 model with easy-entry enabled.
With my SL i can enable the key-dependent but i have to activate it by hand to start it going.
