1 - 8 of 8 Posts
Hi, I have been looking at posts re keys and ppl say press the unlock button and lock button etc.On my key fob I only have 1 large button, is this normal? (I have a 1997 230 slk) Also the range is a bit limited ie I have to stand next to the car to use central locking.
I have changed the batteries and there is a red light that lights when I press the button.
Any thoughts ?
The red light is the battery condition indicator
part 155 one button
check your world famous owner's manual for more key info :D
Premium Member 2004 SLK200K
I believe the first keys were of just one button and worked by infra red not RF , check your manual for where you should be pointing ..
key
It does say in my manual, press the unlock button and lock button, but Ive only 1 big button, also says in the manual it uses radio signal ...I would hazard a guess and think my manuals may be for a latter model....
what year is your manual? earlier than 2000 model year are tough to come by.
but as Craige said, it probably uses ir and not rf so you should point it at the door handle within 3 feet or so
Thanks curro, that link was exactly my key.and as I did change the batteries I shall re sync the key....
Thanks also to all who replied, I think these forums are the dogs do dahs.....
1 - 8 of 8 Posts
