1 - 8 of 8 Posts
Just Got a 2002 320 SLK..Got 2 fobs, one works perfectly and a newer fob with new batteries installed properly, which operates locks and ignition manually, does not remotely. I have seen several posts and internet searches on how to reprogram, but to no avail. Does anyone know the CORRECT process for reprogramming? Thanks for any help
Want to post a picture? Start a new thread or make a post, click ‘edit’, click on the ‘paper clip’ or ‘advanced’ and/or ‘manage attachments’ then ‘choose file’ then ‘upload’ and ‘submit’!
Post your vin in the Vehicle Datacard Request section to get a datacard (options on your car). http://www.slkworld.com/vehicle-data-card/
take to dealer to reprogram
only dealer can reprogram.
Have you tried this?
"Place the key in the ignition., turn to position 2 and push the unlock button on the fob, repeat for the lock button. Turn to position 0 and remove the key. Both buttons should work."
1 - 8 of 8 Posts
