I had 1rst and reverse gears only (1rst, not 2nd) and found a blown 5 amp fuse in the main fuse box that says it is for top indicator light and transmission and upon replacing it I lost all instruments and lights in instrument panel and now starts twice for 3 seconds or less and dies then will disable starter and I have nothing till I unhook battery and then upon reconnecting battery it just repeats. It was saying in trans codes no info from speed sensor 3 which come from ABS unit. Scan on ABS says no signal from rear wheel sensors but get proper readings on all 4 sensors where they hook in to ABS unit. Replaced ABS unit no change. Engine runs right for the few seconds that it does. No fuel pressure problems. Manual says there is a traction control module in right rear of engine compartment. It does no exist. Local shop says it is all in the ABS module. TIRED
shifting issue here:
http://www.slkworld.com/slk-r170-general-discussion/316673-shifting-problem.html#post2583305
