1 - 13 of 13 Posts
Hi, just got my car (SLK200) back from a anti-corrosion job - but they could not jack the car due to a missing jack pad in the front right corner...????? Can you get one for replacement or is it a job for the dealer to fix??:|
Founding Member 2006
i believe you can get part and install it yourself
but i've been wrong before :D
post your vin and we can see if we can get u the part number
2005 SLK350
Not much money and very easy to install. It is made of a durable plastic with a large center plastic screw. The screw should be in the out position (but still in the pad), pop the pad into the mounting hole and then push the screw all the way in. It does not screw in but rather it pushes in. Job done.
part 160
this list is from a 2004 slk 200 but post your vin if u want your datacard
Standby...
Here is datacard part number is the same
* Founding Member #2
2008 SLK55 AMG
Just an FYI: for those with R171 AMG body style side skirts, the rear jack pad part number is a different part number than the front.
2007 SLK55 AMG
For AMG models (May be same for non AMG)
Rear P/N: 171-998-00-50-MBZ
Front P/N: 203-997-01-86-M36
Pelican parts has these for ~$8 each. You'll need 2 front, 2 rear.
Then, order the jack pad from Amazon for ~$9 (square block top, round bottom).
Notice how the rear mount has a lip. (attached photos)
1 - 13 of 13 Posts
