As my dad would say, "You have certainly gone and done it this time . . ." Made the deal on the Designo-Orange '00 SLK230 and will get to Fremont early in the week to pick it up. This is my first MB and first drop-top so looking forward to a long term relationship. Would appreciate any advice on "pre-flight" inspection -- will certainly check all fluid levels, not sure about tire pressure or any other good things to check out before I head back up the coast to Eureka (might run HWY 1 if the weather is good). What should I "listen for" as I drive? I have good mechanic's ears . . . I hear a car well and often diagnose an upcoming problem from a change in sound. The car has a good service record with MB in SF and only 61K so I expect it to be pretty much perfect (one owner). I did verify that the oil has been changed (with Synthetic) and I know to run premium in it (I always run Chevron in my cars if they have fuel injectors . . . is there a better gas for the SLK?). Any suggestions/advice would be appreciated . . . it will be about a 300 mile drive.
Doyle
oh! the checklist:
Try this checklist
Courtesy of Omnipotent:
Things to look for during car pickup
- Cracks on all lenses of the car
- Front/back/side/mirror
- Look for condensation
- Wheel rash
- Scratches
- On body panels
- Underneath front and rear spoilers
- Edge of the hood near windshield wipers (occurs when wipers lifted to clean windshield – should be stopped up instead)
- Locking
- Glove box and centre console unlocks with doors
- Bass vibration in passenger side door
- Oil level is full
- Seat memory works
- Command screen has no defects
- No scuffs or other damage on leather seats
- Latest NAV DVD
- Driver Assist settings
- Curbside parking mirror assist turned on.
- Easy exit on
- Memory seats set
- Loose items present
- First aid kit
- Warning Triangle
- Micro fibre cloth
- Antennae Remover
- Both sets of keys
- Owners manual
- Spare Tire
- Jack and tire iron
- Aluminium Door pins installed (ordered accessory)
- Rubber floor mats AMG?
- Gas tank cap
- Boot Tray (ordered accessory)
- Remove dealer insignia/license plate holder
- Gas tank full
- Less than 100kms
- Operation Test
- Roof
- Windows
- Locks
- Test sound system with CDs
- Power Seats
- Power Mirror
- Steering wheel adjustment moves up/down/out/in
- A/C and Fan (all speeds)
- Air Scarf
- Heated Seats
- Alarm
- Test Drive the car
- Radio off and listen
- Wipers and washers
- Horn
Bring
- CD
- Flashlight
- Small mirror
From MLC SLK:
1. Check for scratches under the lower edge of front bumper cover
2. Check for paint chips along the rear edge of the hood where someone may have inadvertently lifted the wiper arm into the hood edge. A paint chip on the wiper arm itself should raise some suspicions.
3. Check panel alignment below doors
4. Check to make sure that both rubber bumpers on the lower rear edge of the rear window are in place. These bumpers protect the plastic cover in side the trunk from being scratched by the window frame which rests on the cover when the top is down. You can only see these while the top is in the process of being lowered.
5. Check the tire pressure.
6. Inspect whole car for dings, dents and scratches, including alloy wheels.
7. Inspect interior for scrapes, etc.
Make sure everything you ordered is actually there, including accessories.
Check spare tire and the special lug nuts that it may need.
Check fabric wind deflector
Check operation of major functions like air conditioning, Airscarf, Nav system, CD changer, interior lighting, power seats, heated seats, and so forth.
Put the top up and check for wind noise and creaks/rattles from the roof.
a couple of thoughts....check the windshield and other glass surfaces for chips,cracks and scratches... check the tires and rims for any sign of
abuse...check the headlights as well for any imperfections....
Check the seats.
1- Make sure there are no damages to the leather.
2 - Make user there is no squeeking noise when you sit and rock the seats back and forth, etc.
Check that the VIN number is the same as we have been told.
I had my first broken part....the pin holding the hinge of the plastic shell retaining shield in the trunk broke causing the hinge to come loose and the shield to come off track....naturally they had to order the part....could have been worse- it could have been the roof !
Plastic aerial tool to remove it
You have the correct mats
Remote roof works, if you have chosen it
Have someone else with you to check the paint work.
Check the roof cover is flush when roof is down
Full tank of petrol
Drive the car at a high enough speed to verify that it does not pull to one side or the other.
Somebody stop me!!!!
Day of Pickup
List of things to bring
CDs and/or tapes to test sound system
Tire gauge
Good flashlight (don't count on the glove box light being fully charged)
Small handheld mirror (for looking under/behind things)
Order paperwork in case something comes up missing, there is a price difference, incorrect customization, etc. Don't forget your Car and Key Memory settings.
Calculator (in case you need to check some numbers on the financing)
Camera (optional)
Inspection – Complete BEFORE signing any papers
List of things that should come with your car
Owners Manual
MedKit
Traffic Triangle (Not on US Models)
Any extra manuals or loose options you ordered (mats, racks, etc)
Matching alloy spare (and jack while in there)
Inspection Items
Check the VIN with the paperwork you brought. Is it your car??
Check the mileage. It should be low (some say less than 150, some want it less than 10)
Check for shipping damage
Under front of car, check lip
Hood padding (present and matching color)
Scratches on tires (including spare)
Scratches on paint. Check in bright fluorescent light if possible
Dents. Caution points are bumpers, corners, near wheels, etc.
Check the exterior (and interior) trim for consistent color and properly affixed (no loose ends)
Condensation in headlight covers (leaking water from carwash).
Interior scratches on trim, lining, dash, etc.
Check the seats for damage. Tears, scratches, marks, etc.
Carpet, did you get mats? Do they fit right?
Function Inspection Items
Headlights, side, rear, fog, etc.
Blinkers, flashers
Interior lighting
Flashlight in glovebox
Power seats
Power mirrors (including right mirror autotilt on reverse of equipped, does it return to original position)
Do doors close properly and securely? No odd vibrations? Same for trunk. Does the trunk stay up on its own?
Fan operation (all speeds)
CD, nav system. You might look up the coordinates of the dealer ahead of time, but the nav system should show the map anyway.
Key fob functions. Everything moves and/or opens properly?
Did you get wheel locks? Are they installed? Where is the key?
Do all the windows work? Do all the window controls work (from all the positions)?
Pre-Test drive Checks
Have dealer show you the proper operation of all the functions of the car. Adjust this for your own options and needs.
Fluid locations (and levels), lids secure, no apparent leaks or drips.
All wires and hoses look well secured (no last minute repairs rushed and not properly re-secured)
Tire pressures
Have dealer show you where the battery is, and where the jumper cable connectors are in the front
Check the gas cap. If this is loose your check engine light will light (and stay lit for some time).
Test Drive
Check function of heater & AC, make sure both work, even in the "off" season.
No odd noises
Car tracks well (alignment issues)
Car brakes straight
No hesitation of engine
Post test-drive
Discuss any concerns from the test drive.
Have dealer show you the service area. Do they suggest (or offer) and early checkup before the first oil change?
Does the service department offer loaners or pickup/drop off services? This might be a good time to find out.
Some dealers offer free carwashes. You might ask.
Paperwork
This is last. Double check all the numbers with the paperwork you brought with you. Use your calculator if needed!
Verify VIN and options to invoice and financing paperwork
Are you considering any extended service warranties?
Ask dealer about the roadside assistance program.
Get copies of EVERYTHING!
Dawn it Jbanks with a Preflight list that long poor Doyle will never be able to leave the Dealership. LOL. You are the master when it comes to Preflight check lists.
Premium Member 1998 SLK230
