1 - 12 of 12 Posts
i was just wondering if there is an upgrade for the 230's supercharger
myslk230 said:
do you have pics of these on your car?
Yes, but just looks like standard pulley just bigger.
Fuel reg looks the same.
MAF is just moved up on pre 2000 models to same pos as post 2000 models.
Bazzle
Premium Member 2006 SLK55 AMG (Kleemann K2)
I assume just pulleys are available for the 230, you could always use different spark plugs, ecu upgrade and aftermarket exhaust to achieve better results
The crank pulley is bigger. If you were to change the pulley on the S/C, then it would be smaller. Some of the first mods had the smaller S/C pulley, but there was significant slippage with the smaller size. Most mods now increase the size of the crank pulley.
You can purchase the same pulley that ASP sells from JDS Performance and save yourself about $85 ! LEt me know if you need a phone number....and don't forget, you'll need a longer belt to go with it...the girl at ASP can give you the part number then you can order that as well from David at JDS....and you'll love the difference in power!!
1 - 12 of 12 Posts
