1 - 13 of 13 Posts
I'm a new owner of a 2007 SLK280. It doesn't have the Command system and I would like to know if anyone has advise on installing an adapter kit which would allow me to listen to my music using my iPhone. I'm not fussed about having the phone application, but the music would be nice. Thanks in advance
Sadly Woolly has passed away
Welcome from NE England. Do a search on the forum for Dension Gateway 500. That will do exactly what you are after.
Meggieb,
Thank you,
Founding Member #12/Moderator
Welcome from southern California. Do you intend to keep the current head unit? If yes, then Woolly's suggestion is prolly the best way.
aka John
Welcome, and what Woolly said! Personally, I think if I had an A20 head, I'd be seriously considering replacing it with an aftermarket head....
Welcome from Michigan.....
Hook up the factory AUX connector in the glove box, factory iPod interface which displays in the center of the speedo and utilizes the steering wheel controls, several options from incartronincs.com, new head unit, FM transmitter... there's plenty of options.
1 - 13 of 13 Posts
