1 - 8 of 8 Posts
Bought a 29K Mile SLK55 this week, ported the intake elbow already and now building an intake. Going to go with a needs wings style setup using a VRP 80MM Y Coupler(they have a 74MM adapter) two 45 degree aluminum intake pipes, two 45 silicone couplers and Spectre 3" inline canisters on both sides.
Stock filters have a flow capacity of 457 CFM(K&N) the Spectres have the same..... another option would be the 4" inline filters but I think the 3" are sufficient. I am banking the straight shot will have more velocity than the stock intake.
I ran the same setup on my C32(RIP)
Registered 05 SLK55 & 06 Kleemann 55K S8
I doubt you will see any real performance increase. You need to look at the bottleneck in the system and that is the throttle body area. Both the Y that feeds it and the TB itself. If you are doing this for more sound, then knock yourself out as there will be more intake noise goodness.
Premium Member 2005 SLK55 AMG
Hi All
I went the Kleemann tube header route + ECU flash give me an extra 50 Bhp on Dyno. Had it 3 or 4 years now no problems . Its a bolt on upgrade .
Also it sounds like a V8 now. check videos in sig
Cheers
Andy
How is the header sound at cruise.... promised wife I wouldnt "ruin" it for her..... I have a lot of toys including a SL600 thats modded/tuned.... I would love to do the headers
You won't ruin it at all. At cruise it is nearly the same. I have headers and a full exhaust and it still isn't bad, but there is a little extra noise. Step on it though and she snarls pretty good >:D
Hi All
As already said sounds like standard when cruising , But step on it & you can make small children cry & young single mothers swear.
Cheers
Andy
1 - 8 of 8 Posts
