Hi Everyone. I liked the welcome that I received yesterday.....the world is such a small place.:D
I have a 1998 SLK230 R170 with the common roof problem and feel that I can fit seals if only I could get to them!
The problem is that my roof will NOT OPEN in any way. I've replaced the RHS trunk ram as I thought it was the problem, as the only action is from the LHS until things jam up. There appears to be no leaking fluid and levels are full.
The trunk is stripped to as much as possible but all rebuilds that I read about are possible when the top is half open. How do I open it?? Can I rebuild the top opening ram without it's removal?
I've read most of the threads but none give detail of how to manually lift the top. I really don't think I have a switch problem but others may have a different view. It feels that a latch may not be releasing.... but why does the LHS trunk move up 2 inches and that's it? I can't get to much to check all the bits. Cheers from Barry in AUSTRALIA F)
moving to r170 general discussion
Hi and welcome to the forum
in the owners manual there are directions to raise and lower the roof manually.
This may help to start you off with fault finding.
best place for parts in australia is:
MB Spares
PHONE
From Canberra and surrounds, 6239 1099
From within Australia, 1300 787 300 for the cost of a local call.
From outside Australia, +61 2 62391099
FAX
From within Australia, 02 6280 4596
From Outside Australia, +61 2 6280 4596
BY SNAIL MAIL
M.B Spares and Service
14-16 Lyell St
Fyshwick ACT 2609
Australia
Emergency roof operation.
MB Spares
PHONE
FAX
BY SNAIL MAIL
14-16 Lyell St
Fyshwick ACT 2609
Australia
Thanks for your suggestions but on page 23 of my owners manual it only describes how to CLOSE the roof by emergency procedure.... not OPEN it as I require. I'm still waiting for clues as to handle this problem. :hb:
Just put some wd-40 on the micro switches in the roof by the windshield... there's a procedure here somewhere if not I can give you pictures in a day
Thanks. I did in fact find the problem. The release cable had slipped off the RHS trunk ram preventing the trunk from fully opening. One this was fixed the roof worked perfectly many times.
