Registered 2004 SLK32 AMG
Well it's not really a problem because I have no problem starting the car or turning the key in the switch, but when I just insert the key fob in the switch without turning it, the key is all loose, I can wiggle it. It feels cheap ??
What do you think is it and what should I do ?
Loose bezel? Worn tumbler? Worn barrel?
To be fair, the latter two are normally indicative of a sticking key so check the bezel first - key in position 1 and see if the chrome ring moves any
Ok I'm gonna check the bezel and let you know. Car has only 45k miles (72k kms)
Well the bezel move a little. Is it supposed to be thigh ?? I don't know how it should be, I did not bought the car new !!
