1 - 9 of 9 Posts
2007 SLK350
Hi, could you please help me identify what for are the disconnected ones? And a diagram to reconnect?
I think it is something related to AC Heat ?
Hood Automotive tire Motor vehicle Automotive design Automotive exterior
2009 SLK350
Which side of the car and is the top of the pic the front? If no-one else checks in I will try to get a pic of mine.
2005 SLK350
The two nipples togehter are the heater input and the one seperately should be the return line from the heater coil. See attached:
2007 SLK350
Discussion Starter · #6 ·
Thank you very much, for taking the time. !!!
Will try to solve this and will send pictures once it is solved.
2005 SLK55 AMG /2005 SLK350
In your first picture, top-left corner, there is a red cover. Can you take a photograph from about three feet above this cover, with the camera pointing straight down? I'm looking for your duo-valve, which controls the heat.
2005 SLK350
Here is a picture of the duo-valve. This is what you are looking for. Is it there?
Automotive design Motor vehicle Trunk Audio equipment Automotive wheel system
2005 SLK350
Looking carefully again at the first picture, it looks like there are a lot of aftermarket hose clamps on heater hoses. If my guess is correct, the two hoses from the duo-valve have been connected to a 3-way T with the third of that 3-way having a short section of hose that connects up to the return hose. If this is correct, then a prior owner may have had a leak in the heater coil and decided to by-pass it, lose having heat, and save a bunch of cash required to take the dash apart to replace the coil. A lot assumptions here.
1 - 9 of 9 Posts
