1 - 14 of 14 Posts
First please update your vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t.
Follow exactly to update: ‘Usercp’ at the top of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘vehicle’. Info in your garage does not update your profile.
Hi and welcome from the UK Midlands! :)
I can't help with advice on lowering your SLK, but I'm sure someone that's able to help will soon contribute some useful advice for you...
My SLK 55 sits low enough, I'm really scared of curbs and parking lot concrete blocks so much that I usually back into the parking spots. I'm not a big fan of lowering, but good luck somebody will chime in shortly.
I don't get a like? Wahhhhhhh
I's tough to be liked. :D
Welcome from Hillsboro, Oregon! There's only one way to lower a car properly, and that is to replace the original springs with shorter, stiffer ones. When doing so, you also have to replace the shocks since those are matched to the spring (length of travel and rate of damping). Have a troll around the R170 section of the forum and I'm sure you'll find some options from the likes of Eibach and H&R. Fitting the factory SLK32AMG springs and shocks is also an option.
Super Moderator/Florida Event Coordinator
Welcome from central Florida, USA.
1 - 14 of 14 Posts
