I recently bought a used 2001 SLK 320. Both the electrical seat adjustments don't work as well as the button to retract the convertible hard-top. I checked the fuses and they are ok. Is there a "control unit" that control all/most interior electrical functions? Hard to imagine that both seat motors broke as well as the electrical for the hard-top. I really need help because car not passing inspection secondary to seats not adjustable. Thanks
New members and guests should be aware that the 'New Posts' link next to the 'Search' link top right of the info bar is a great way to see all of the posts you have missed since you were on the forum last.
Thank you,
Founding Member/Moderator
Premium Member 2002 SLK230K
Welcome from New Hampshire. The hard top issue could be any number of limit switches located through out the car. If i can find a chart showing where they are that may help some.
