1 - 9 of 9 Posts
Hi all my car is making a humming type noise once i getpassed 30mph from the front end it doesn't get any worse as I speed up to 60mph in a strait line, however, what I noticed is if I turn the steering wheeljust a tad to the right the noise stops but when i turn it to the left it'sstill there. The noise is rotary innature so I belief it's the wheel bearing or bearing starting to go. So I'm looking for second opinion. Thanks
:frown:
Yes I did do a search and read the one about front end noise but it not quite what I have so that's why I asked the question on the site.
Thanks. :wink:
The power steering fluid is fine. Thanks to input. :tu:
Registered 1997 SLK230
I have had this on several cars including my R170 230. In every case it has been a wheel bearing. The fact it stops when you steer right would confirm to me that your front left wheel bearing is probanly the cause.
Sent from my SM-T710 using Tapatalk
Snap! Twas the same one on my 230. The fronts are a piece of cake to change compared to the rears so did them both. Gave me the opportunity to take off the brake backing plate, de-rust it and give it a lick of paint. Another little job ticked off...
Sent from my Nexus 7 using Tapatalk
Thanks for reporting back.
Helps the next person searching to see a successful solution :tu:
1 - 9 of 9 Posts
