1 - 9 of 9 Posts
Registered 2012 SLK350
I recently purchased a 2012 SLK 350 that I am having transported to my home sometime next week. The carrier is understandably adamant about disabling any alarms before transport. I looked at the online manual and found what appears to be a button to disable all theft or movement alarms, but not having an actual SLK in possession yet I can't accurately describe to the far-end salesmen on how do do this. Can any of you provide instructions I can pass on for how to do this. Pictures would help too.
Thanks,
Dave
send him the link for the online manual
or
send him to
this one
2012
you just did.
Should also be a link to the manual in his introduction thread from you jbanks15.
Premium Member 2014 SLK200
The instructions below refer to the switch in the overhead console:
Deactivating
To switch off: unlock the vehicle with the key or KEYLESS-GO.
Tow-away protection is switched off automatically.
Deactivating
images/img56991e275d290550351f191538d0fb6a_1_--_--_JPG72.jpg
Remove the key from the ignition lock.
Press button
Indicator lamp
lights up briefly.
Lock the vehicle with the key or KEYLESS-GO.
Tow-away protection is deactivated.
Tow-away protection remains deactivated until:
  • the vehicle is unlocked again
  • a door is opened and closed again
  • the vehicle is locked again.
To prevent a false alarm, deactivate the tow-away protection if you lock your vehicle and it:
  • is being transported
  • is being loaded onto a ferry or car transporter, for example
  • is parked on a movable surface, e.g. in a split-level garage
Ah. News to me. 👍
Thanks for all the responses. I did see that information in the online manual, but did not have a clear image that I could use to convey the proper buttons and procedures to use. For some reason I cannot see any of the images provided by Windinmyhair. The images directory and file names are visible, but the links don't work.
Dave
Thanks, but I don't think I need really the images now. I saved the image from the online manual and then blew the .jpg up to where I can clearly see that it's the rightmost button that does the function.
Dave
1 - 9 of 9 Posts
