1 - 12 of 12 Posts
Hello,
Im new in this forum and a new owner of a slk 350 ,2007.
Ive had th 170 before and i just love the slk cars!
Mt questin is if somebody can post a guide or pictures of how to check/change the spark plugs on a slk 350..
aka John
It's pretty straightforward, and I thought was covered in the DIY section, but I can't find it at the moment.
Basically 5 years / 100k miles is the recommendation - remove the air cleaner, and prepare to get your hands dirty. Pull the coil covers. It also helps to have a valve wrench to help remove the .plug boots, the last ones (nearest the windscreen) are a pain in the arse to get off..
Darkic,
Thank you,
Sergeant-at-Arms/Moderator
Darkic, have you done plug changes before ? It really is fairly easy, but one must have patience unfastening the plug wires from the coils. I used a small bladed screw driver to free the "clips"... you'll see. Also, I had to use a 15" breaker bar to get the plugs free(those things were tight) . Hopefully you won't need to do that. IF the plugs ARE tight, do not strike the wrench(spanner?) with anything (like a hammer), just use steady "muscle" to get them free.
Good luck.
I have changed plugs on many cars before but when i opened the hood on my slk 350 i was just lost.. haha and that they are 12 spark plugs it just confuse me but i will give it a try!
Thank alot for the tips!
here is another tip:
aka John
M272 has one plug per cylinder, so you only need 6, unlike the M113, which does have 2 per cylinder for a total of 16.
Did I miss 6 when I changed mine... :biglaugh: Sorry, I couldn't resist, especially since John had already answered. Most people who haven't changed plugs are a bit nervous, and that's why I asked. It's the air-filter/intake box that is a real pain. Make sure you get the "hoses" off and unclip the "stay" on the back of the box(heavy silver "wire" thingy), then give it a good pull! Be careful putting it back on; it IS a bit tricky(again, you'll see).
My pleasure! I can't remember having a set of original plugs being that tight; darn near pulled a muscle getting the first one out :eek: ...after that, the breaker-bar made it a good bit easier.
By the way, where ARE you located?
Take care!
Hello again!
I have now been updated my info.. and i put up a picture of the car.
Thanx for the tips.. i was confused of the info a read on the net about 2 sparks/ cylinder thats why i started this thread.
Cool! I guess you're a little too far away for me to drop by and "help" you in person :biglaugh:
Enjoy!!!
Thanx everybody!
I just got confused when they told me in Mercedes service that the car has 12 spark plugs i culdent understand where the rest 6 was.. Haha
Thanx everybody!
Mercedes service told you this? I think I'd try to locate a new service or make them a wager; If they can't find the other 6 plugs, the next service is free!!!
Take care!
1 - 12 of 12 Posts
