21 - 28 of 28 Posts
I give up :( :( :(
  • Haha
Reactions: M4rCu5
2001 SLK200K/2001 SLK320
Highly improbable, 7000 rpms is at the very end of the redline ..
For clarity here's a Crossfire based fascia that I created earlier which has the same scaling as the R170...
Big Number on the rev counter is 7 and above it says RPM x1000 which = 7000 RPM (y)
Your SLK will have BIG Number 70 and above that it will say RPM x100 which unsurprisingly also = 7000 RPM (y)
(click)
Font Gauge Technology Circle Auto part
2001 SLK320
Discussion Starter · #26 ·
@AfroNinja you're definitely adding a 0 to your idle rpm. An easy check is going to oreillys to rent a pressure gauge to monitor your fuel pressure and how it falls when you shut off the car. You might have a leaky injector.
Also check/listen for vacuum leaks. It's universal that they will cause issues with idle. After than, you might need to take it in for a diagnostic if you're not mechanically savvy or fortunate enough to have STAR
2003 SLK320
Yeah I just realized what I did, I guess that's what I get for posting on here at late last night 😅 I'll give that a try thank you
21 - 28 of 28 Posts
