1 - 2 of 2 Posts
I am just doing a quick drain and refill on my transmission (not dropping the pan) . how many quarts to refill if I just drain it from the transmission bolt on a 2001 SLK230 ?
I saw some posts that said 4 quarts but not too sure as this seems alittle bit too much especially if only part of the fluid is drained :confused:
4 quarts is about right assuming you're talking automatic. However, why not remove a couple of more bolts while it's empty, remove the pan and change that nasty, dirty filter that is only about five minutes away? Make sure you use the correct ATF.
Len
1 - 2 of 2 Posts
