i really dont know what 2 do :(
i have mb slk200 97,and there is hot air come to me during im driving,i let some1 close the hot from A/C but i still have this hot air,i changed the boot around the steering stick but still have hot air,changed the floor and still have it,i will become crazy from it,pls help me
mohamed
Please update your location/vehicle (model and yr) in your profile as it helps the members answer any questions you might have based on locale and model.
And finally, if you find something useful on your visit here today, please consider becoming a donating member or make a one-time donation to offset development and operating costs. Even $5 is welcome! Thanks!
So , you mean the hot air comes from the normal ventilation grills , but when you turn the air knobs you can't get anything else but hot air ?
In that case, you might have a default in the little pipes that command the air flow behind the dashboard.
have a look over there
http://www.partscatalog.ru/mercedes/1/car/170/465/66E/170.465/66E/83
no no not from ventilation grills,its come from beside ventilation grills,behind stop and fuel,i check the leather boot around the stick for driving and i changed it but still have hot air,its like hot air from the engine,because when the car is cool i dont have this hot air,but when i drive alot and it become warm the hot air come down on my leg,i check the car from inside and outside and there is no any hole :( dont know what to do :(
Maybe there is a firewall grommet missing and it's allowing heat to enter the cabin.
it seems you are missing some part somewhere from underneath.
You should ask a mechanic to have a look, because, if the air is coming in the car, you can also get fumes, water, and noise.
