1 - 20 of 34 Posts
Registered 2006 SLK55 AMG
Quit running at 70mph with low fuel light on. Filled up, won't start or run, except for a extremely brief moment. Can't hear pump or relay. Hoping it's the fuel pump relay. Don't know where located. Any help would be appreciated. Don't know if it's the same location or relay as the SLK 350 etc. Mine is the V8 5.5 ci engine. Thank you for reading. -Eddie-馃槉
Lube those seals:
your brochure:
mods you should do:
smarttop
Since you have a 55, these might interest you
My mods - also check my albums in my profile
and my videos in the 'Driving Stories' section
Kleemann Supercharger:
Kleemann ECU Tune and Headers:
Wavetrac Limited Slip Differential (LSD):
Carbon Fiber Diffuser:
Carbon Fiber Air Brakes/Side Vents
Driving stories section:
My albums:
FREE GIFT! Post your vin in the Vehicle Datacard Request section to get a free datacard (options on your car). If looking for a car, get the options before you buy!
Administrator/Founding Member
see this for locations of parts
HI !!
Welcome from Canada 馃槃
Welcome from Wirral, England.
If you are new to forums, or the format of this forum, this may help.
Our forum rules:
Really useful links (thanks to ixions cataloguing)
The web site of slk-links Includes diy videos.
Spare parts: The web site of slk-links <<<Where to find part numbers
There's a link to R170/171/172's do it yourself threads below.
R170 DIYS:- SLK R170 class DIY
R171 DIYS:- SLK R171 Class DIY
R172 DIYS:- SLK R172 Class DIY
Some useful tips in this section for new Members and prospective owners.
You can find your region by scrolling down the page on this link
This is where to find meets/events.
Look across the banner and you'll see three vertical dots.
Many questions answered there.
You'll also find the >>>FAQs<<<
Click the 5 horizontal lines near the banner.
Scroll down and you'll find a huge section of info.
Check out the tsbs. Lot's of fixes for MB recognised issues there.
Update:
I found the fuse box under the hood, and on the left end of dash. There was a paper in the dash fuse box. It shows the location of the third fuse box on the left, drivers side in "the boot". Still can't find that one. Now I'm having to disassemble trunk linings. Not a simple task. -Eddie-馃槉
Hi Eddie, welcome from Barrhead, Scotland. 馃槃
Registered 2009 SLK350
Welcome to the forum from the DFW area.
Remember to use the search button.
Try this hope it helps
Premium Member 2009 SLK55 AMG
Hi Eddie, Welcome from the Sacramento Valley SLK Enthusiasts!
Discussion Starter #19
Thank you. Thank you all for your kind welcome. I'm still learning this forum and want to thank each individually, but having a bit of struggle doing that.
I have so enjoyed my little SLK "rascal", and can't wait to get it back into service. I'm a mechanic, electrician, AC tech, and bla bla. I knew going in that these fine machines would be a learning curve for me, but isn't everything?
I'm counting on you guys for your vast experience. I've searched for archives on the 2006 SLK 55 fuel relay and fuel pump, but info is so far non existent or not applicable. I suspect that's due to the limited production. Simple things such as exact location of the relay fuse block, best practice disassembly to get to it, same for the fuel pump, just aren't out there or at least not yet found.
I'll get there, but it's looking like I'm as always, on my own to forge ahead which means I will be doing it the hard way, much unnecessary disassembly etc. I know you all know what I'm talking about. -Eddie-馃槉
post 16 above has a link to all r171 fuses and relay locations
1 - 20 of 34 Posts
