1 - 20 of 20 Posts
hi all!!
just bought my first slk, 230 compressor, 1998 only 2 days ago!! the car is awesome, great condition for its age, only 56,000 miles!! just getting to know it at the moment.
i do have 1 questin if this is the rigt place, the drivers side foglight is only fixed at one side, so is wobbling a little, the fixing on the right side of it as viewed frm the front. (right hand drive!!)
Please update your location/vehicle (model and yr) in your profile as it helps the members answer any questions you might have based on locale.
And finally, if you find something useful on your visit here today, please consider donating for security updates, repairs and monthly expenses to the site. Any amount is welcome! Thanks!
welcome and congratulations!!
Perhaps some photos of where you think it is loose on the foglight.
Premium Member 2002 SLK230K
Welcome from New Hampshire. There are two nuts per side that hold the fog light in place. Just in front of each tire there is a little plastic door that will give you access to the fog lights.
hi eddy, thanks for your reply, as you see from the photo, the lamp is not secured at the right side, there is an access panel in the wheel arch to enable you to change bulbs, but its awkward, and i cannot see how it should attach from there. just wondered if anyone knew how it should fix, or will i have to remove some panels etc?
regards
steve
thanks for that info livefreeordie, thats helpful, i at least know what i am looking for now!!!
regards
steve
Another welcome from Atlanta.
Premium Member 1998 SLK230
regards
steve
Steve,
is your car green metallic?
You may be able to reach from the front to find out if its a missing bolt or broken tab. However you will need to go through the door in the wheel well to replace bolts etc.
P.S. the bolts go from the bottom up
and here's a pic to show where the mounting tabs are
Discussion Starter #20
thanks for the info guys, it was a broken tab on the foglight, got a replacement from MB no problem, thanks again!!!!
oh and thanks for all the welcomes!!!!!!
1 - 20 of 20 Posts
