1 - 17 of 17 Posts
Hi, I have been scouring the internet to source some information on my beloved SLK R170 and I came across this website.
I am the owner of an SLK 200 Kompressor R170 - rare 6 speed manual - that has given me so much pleasure to drive over the last 12 months until now.
I recently left the interior light on in my vehicle over night and when I went to the car the following evening I still noticed the light was on. I quickly tried to start my car but unfortunately it made a tapping sound and would not turn over. The following day I jumped started the vehicle with my wifes car which was successful and left the car running for about 20 minutes.
When i turned the car off and then tried to turn it back on I couldnt start it again. The unusual thing was that I could get power throughout the interior of the car and the head lights but I could not get enough power to the engine.
I tried to jump it again which at this point would not work, thinking that the battery was dead I bought a new battery thinking that it might be the problem, but I still couldnt start the car.
I then had the car towed to my mechanic and the following day handed in both of the keys I have for the vehicle. The car has now been at the mecahnics for the last 4 days and they have had no success in being able to start the car. The vehicle has an aftermarket flashpoint alarm installed however I have had somewhere go to the workshop and disconnect the alarm and then try and start the vehicle but still nothing.(the after market alarm is not the problem)
My mechanic is a specilaist certified mechanic from mercedes and he is still scratching his head with this problem. He has plugged the car into the computer and everything is coming up as fine.He has never seen this problem before.
Is there anyone out there that has experience with the same problem? Or a similar problem?... the longer it stays in the workshop the more this problem is going to cost me.
Look forward to hearing from someone soon
Giacinto
I recently had my SLK 350 battery die (the evening before a LONG vacation drive). After the jump, although it started, the computer was very confused and limp home mode would kick in (amongst other things). Required a shop computer "reset". Perhaps that is needed although I would think the mechanic would have tried that.
Premium Member 2009 SLK55 AMG
Welcome from Sacramento Valley SLK Enthusiasts.
Premium Member 1998 SLK230
Premium Member 2002 SLK230K
Welcome from Hew Hampshire. I have been dealing with a problem for over a year now and just recently found the problem. The slk's have a known problem with the K40 relay board, most of the problems are with the pre face lift models. The solder joints go bad and need to be replaced, after having a good look at mine with a 20x magnifying glass i noticed that some of the joint were cracked just enough to create a starting problem, you can't see the cracks with the naked eye. Anyway after fixing the solder everything works great.
Thanks guys and girls for the tips and the welcome. I will let the mechanic know of the recommendations you have put forward and see how they go. i was reading some other posts and all seem to focus on the K40 relay module, hopefully that is the problem.
Mine is however the facelift model of the R170 and most cases of the relay module relate to the pre face lift model.
i will keep you posted.
Your right pre face lift had the problems that's why i never bothered to give mine a close look, i have a 2002 230. Turns out even the facelift models have the K40 problem.
Welcome from Michigan....
Did you ever figure out what the problem was? I have the same issue
1 - 17 of 17 Posts
