1 - 15 of 15 Posts
Hi, new to thhe forum, got a 2004 R171 LHD with a boot/trunk that wont open, the key turns ok to the left so i am assuming its not a WD40 issue and i can hear the electronics in the lock mechanism,,,looking to see how to remove the plastic covering when i enter the boot space from lowering the roof partially,,any help greatly appreciated,,thanks in advance
Premium Member 2009 SLK55 AMG
Someone will be along shortly to help!
Reactions: taffyapple
First please update your vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t.
Follow exactly to update: ‘Usercp’ at the top of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘location’ and ‘vehicle’. Your profile is NOT updated in your ‘personal garage’.
Bill's Den: Documents
Lube those seals:
http://www.slkworld.com/226839-post1.html
your brochure:
Mercedes Brochure Archive
mods you should do:
smarttop
clear or tinted side markers
shorty antenna
led license plate bulbs
led parking lights
Post your vin in the Vehicle Datacard Request section to get a free datacard (options on your car).
Premium Member 2004 SLK200K
Welcome from Madrid ...
Try disconnecting the negative from the battery for half and hour or so , you'll be amazed what faults this can cure ....
Premium Member 2010 SLK300 2LOOK
Welcome from central Florida, USA!
Premium Member 2005 SLK55 AMG
Hi and welcome from the UK Midlands! :)
Good luck with resolving your boot issue...
Discussion Starter · #12 ·
Sirs/Ma'ams,
Thanks for all your welcoming replies and help with the boot issue.
Tonight i gained access to the boot/trunk by lowering the roof to the first stage, allowing me access into the boot/trunk, to see that the problem is the cable wire between the lock and the latch being fixed and not moving as the key is turned, therefore the problem being in the lock side and not the upper latch mechanism,,,,
Any solution would be greatly appreciated,,,thanks in advance Simon
Hi Simon, welcome from the North of Scotland. :smile:
I had a similar problem. The cable doesn't move when you turn the key. The key contacts a micro-switch, which unlocks the trunk. To me, it appears all electrical. Not sure if it will work if the battery is disconnected.
My problem was the electrical plug coming loose from the micro-switch. Probably due to my wife shutting the trunk lid too hard. (She doesn't do that now after I spent a lot of time tracking down the problem in hot and humid SC.)
1 - 15 of 15 Posts
