As the result of OBD 170 fuel trim code and intermittent hesitation mechanic replaced MAS ($588 + Labor). Intermittent hesitation continued with fuel trim, shift solenoid and misfire code. Mechanic replaced plugs (not wires). Hesitation continued - checked for vacuum leak, fuel pressure good. Replaced plug wires and she runs like new again - 30 mpg hwy. and quick off the line.
Clean MAS before replacing and change wires when plugs are changed.:rockon:
Should read NEW Mechanic replaced plug wires. As a first time user having difficulty figuring out how to edit my post.
If you do not see an edit button at the bottom of any post
You then need 15 posts to edit
Go welcome enough new people to get to 15
