I have a 98 slk 230 for a year now. The first and most common sign that I have is in putting the top down, the windodws go down, the back trunck raises, the top comes unlatched and then everything stops moving and the top doesn’t retract but the pump continues to run. I have also had instances where the top was down and in trying to put it back up, the back trunk raises and the top gives a little nudge but does not go up and the pump continues to run. Here the trunk sometimes gets stuck open back and stays or sometimes decides to close but I stay with the issue of the open top. Only about 30 minutes after does it go back to place when the car has been off and left alone for a while please help I have no clue what to do
First please update your location and vehicle (Put Looking!)(year?: 1996-2018, model?: 32, 43, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
On a smartphone: http://www.slkworld.com/new-members-introduce-yourself-here/330737-how-update-your-profile-post-intro-smartphone.html
