New to the slk fourm.
Last week my 2001 Slk 230, low beams stopped working :td:. I replaced the bulbs didn't help, high beams work fine. Changed light switch/fuses, everything is woking fine, just no low beams. Really trying to avoid the shop. ANY ideas??
moving to r170 general discussion from general discussion
Moderator/Founding Member
Hi
Not that i know much about MB or their electrical systems but i would check that you have power to the lowbeams may be a faulty dimmer switch.
Pull plug of the back of the bulb and with either a test light of a multi meter check for voltage.
