1 - 18 of 18 Posts
i have recently purchased a slk 200 all working well
apart from the water temp gauge in the instrument cluster
the feature is there but it does not show any temp on the bar graph
any ideas?
Please update your location/vehicle (model and year,ie 2007 SLK 350) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t.
Follow exactly to update: ‘Usercp’ at the top left of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘location’ and ‘vehicle’. Your profile is NOT updated in your ‘personal garage’.
Welcome and thanks for joining.
The 200 won't have oil temperature ..
I'd start by checking the electrical connections on the temperature sender - I'll dig out the location first thing
How does the car perform ..? Without that data, it may run oddly as it's not sure of the engine temperature ...
Edit - assuming this is a R171 until the OP updates his info ...
Premium Member 2009 SLK55 AMG
Welcome from the Sacramento Valley SLK enthusiasts!
Premium Member 2007 SLK280
A warm welcome from Southern Arizona. Good to have you on board. Best of luck getting your temp gauge working. Enjoy the people, the forum, and top down cruisin'.
Thanks all ,
Yes it is a 171 model 2005
It's the water temp that's not working , also now found the reset button to
Change the clock also doesn't work , so can't change time either .
The reset button is usually an easy one - I'd guess at some point the Instrument cluster has been removed - the three buttons on the side are connected by a small ribbon cable on the rear of the cluster (held in with one of the computer type ribbin cable locks) - I'd hazzard a guess that the ribbon cable has come loose, or wasn't put back in properly
Pretty easy to remove the IC and check this ... (have a search on here...)
I'll try and snap a pic of my old AMG cluster later
The coolant temperature sensor hooks into the front SAM - it could be a loose connection here , or on the sender it's self
This Youtube vid shows the sensor being changed out on a C class, but with the same engine as yours...
https://www.youtube.com/watch?v=Oyobl5jBCI0&feature=youtu.be
or
Sadly Woolly has passed away
Welcome from NE England. Congratulations on your SLK.
Woolly - Founder & Super Moderator.
Hi, welcome from the North of Scotland. :)
I think (at least on older motronics) the ecu assumes 0c on startup and 100c after some period of running if it can't acquire a signal from the temp sensor. I just repaired a temp sensor on Jr's Volvo where the connector had gone bad due to age and heat. So check that first!
1 - 18 of 18 Posts
