so i noticrd the fluid in my 01 slk 320 was at at the low mark on the roof pump and that the deck would not close after the roof retracted. thinking that the low fluid was the cause i followed prviuos commentators of depressurizing the system and filling the pump thru the port at the top. i had to remove the brace on the top right wheel well to get better access to the pump refill orfice.
i buttoned everything up and now i have no power to the roof, the rear window defroster switch and the trunk illum light. i changed the relay to the pump,checked the #7 fuse and the top fuse. still no power. any ideas?
Want to post a picture? Start a new thread or make a post, click on the ‘paper clip’ or go to ‘advanced’ and then ‘manage attachments’ then ‘choose file’ then ‘upload’ and ‘submit’!
put this:
portland and 2001 slk320
in your profile like this:
then we can all see it on the left hand side under your name
questions?
