Hello,
My second rear tire change out...from the originals to Michelin Primacy MXM4'S
that lasted just over 3 years or 12,000!
They were quite,responsive,stopped,every time! It is they did not wear well at all, which is the norm, I am learning......
Any good straight opinions on replacement's The Michelin appear to be rated fairly high on most sites.....
Regards
Jecjr
Hello,
Regards
Jecjr
By and large you have to choose - tyres which corner well and stop well, or tyres which last a long time.
That said, 12,000 seemsm a bit ligthweight. Depends on how hard you gas it I guess as heavy accelleration will wear them faster.
Thanks, I do drive, like I love it!
I will most likely stay with the michliens.
Cheers!
Running Continental DWS (http://www.tirerack.com/tires/tires.jsp?tireMake=Continental&tireModel=ExtremeContact+DWS). I like them a lot. Replaced all 4 about 18 months ago and just had to replace the rears 2 months ago. The fronts are in great shape. From what I understand this is pretty normal for an SLK. My Harley is the same; two rears for every one front.
I would think that unless you are going to change all 4 tires you would want to match the fronts and rears.
