My name is Dexterln, I have a 2001 SLK 320 with 143,000 miles. Right now I am having an issue with the shifting. I noticed yesterday that while I was driving that it would kind of jerk a little bit but then it drove regularly. Now this morning it will not come out of what seems to be second gear. Also when I move the selector shift from P to R or D there is a hard jerk. Any help would be greatly appreciated.
moving to the r170 general discussion section
forum help is just for the forum operations and help with the forum, not with a vehicle
New members and guests should be aware that the 'New Posts' link next to the 'Search' link top right of the info bar is a great way to see all of the posts you have missed since you were on the forum last. Remember to click 'mark forums read' under quick links when you leave.
Thank you,
Moderator/Founding Member
Registered 2005 SLK200
Have it checked.... ATF level and condition as a start....You must change it if you do not know the history of the vehicle....It is best to do it in an MB-shop as they know those transmissions. If it is the transmission fluid, then it won't be that expensive...
Premium Member 1998 SLK230
yes have your transmission fluid changed as well as the engine/transmission mounts.
Your car not wanting to shift out of 2nd gear to 3rd or higher is a sign the car is in limp home mode, so it won't do more damage to the engine/transmission.
Is the check engine light on?
Cost
I just had my transmission flushed and differential changed last week at a Benz dealer in MPLs. Minnesota. Cost was dang steep I thought. 175 for the diff flush.
And 280 for the transmission flush.
My car has 110k on it. What I did notice was it shifts at a higher rpm now I wonder if the dealer reset the shifting sequence? Maybe you can do that to help too.
