Hello
I drive 2002 mercedes benz slk r 170 230k 197psm 111engine.
I am trying to buy crank pulley tuning kit from germany. They want the diamater from me.
Is there anybody out there to tell me the diameter for crank pulley?
I want to know exact size before i compelte my order.
Help! Thank you
Premium Member 2002 SLK230K
Welcome from New Hampshire
Not sure what the size is, best bet would be contact your dealer with the VIN and get the size.
Hello
Help! Thank you
First please update your location and vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Hi witch983,
We ordered ours from Speer in Germany and had to measure ours. It was easy to measure it. Ours was 185mm. But that doesn't mean yours is. I'm assuming you've had a gander and tried to measure it on the car?
Factory outer pulley size is about 185mm measured from the top of the grooves. ASP for 2001+ is 8.4" (about 213mm). This change is only for the larger of the two rings that drives the supercharger and alternator. The ASP is a 15% increase in size.
It is either 185mm or 192mm outside diameter. Try to messure under the bonnet and be sure you messure outside diameter.
On my 230 kompressor facelift 197HP it is 192mm OEM, you have the SC MP4 generation 4 and can increace to 222-225mm with okay stafety margin.
