1 - 18 of 18 Posts
Hello SLK World,
I have 2006 SLK 280 coming a radio and 6 cd changers. I wonder how do you guys upgrade to DVD player w navigation system? Please, can someone help me posts a lists dvd players w navigation system will fixed 2006 SLK 280. Also instruction to install. Here's the pics of my radio. I have a feeling it's a pain to upgrade GSP. thanks for help guys
If you wish to PM (Private Message) someone, you need 15 posts. To get those 15 posts quickly, just go to the ‘new members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM.
Welcome from Indy!
Welcome from Los Angeles. I'm not sure that anyone has done that upgrade with a stock sound system.
Premium Member 2009 SLK55 AMG
Welcome from stormy Carmichael Northern California.
Welcome and do a search. check Ghostdunks for aftermarket options.
One can also retrofit the COMAND NGT 2.0 from the pre-facelift models with the Nav-DVD system in the trunk/boot. This is OEM and may be more reasonable now with ebay suppliers. Again, please do a search.
Discussion Starter #16
Thanks for help. Do i have to replace sound system by adding a Nav-DVD system? and of course i would like to take out the Radio. what' is command do i have ? again thank for helps
From the photos you have the A20 unit. This can be replaced with the COMAND head unit (has a larger 3x5 approx. screen), the pre-facelift COMAND unit is designated NGT 2.0. Since this is old, it can be bought at a lower proce from ebay sellers. The Nav-DVD unit is added on in the trunk. IIRC, Bleen may have his old unit but I don't know if it was sold or not.
I am not sure if you need an amp or AGW (audio gateway) or not since you do not have the Harman-Kardon set up. Others who are a lot more knowledgable may chime in.
Welcome from Michigan.....
1 - 18 of 18 Posts
