1 - 9 of 9 Posts
Heater fan started to run intermittantly.
Thought it was either regulator or HVAC controller. Dropped fan out from under dash..
Brushes worn out. Soldered in new ones ($35), good as new :bannana:
Bazzle
Founding Member
Hello Bazzle,
Great to hear about DIY on the SLK. :bannana: I'm horrified about the MB costs here in the UK, £90 per hour plus parts and no actual certanty of a fix. Normal response to your fan problem would have been half a days labour plus new fan with a total cost of around £500 !! :mad:
I have a similar issue. When I first get into my car and switch on the blower it goes full speed, down to nothing and back up to a faster speed etc. It is very erratic until it warms up a bit. AC also doesn't blow cold and there is a screeching noise like a slipping fanbelt behind the glovebox somewhere. Some pointers in how to remove and replace would be useful. Save me carving up my dashboard !
In your situation it might be the actual controller and not the blower. I changed mine and sometimes does the same thing as you described. I usually go full and off, full and off on the controller, that usually fixes the problem?
1 - 9 of 9 Posts
