Headlights - need some help - the Right Side (drivers) headlight low bean appears not to be working. When you turn the headlight switch to position one - both side lights come on, when you turn it to position two - the left low beam comes on and the right side stays out. The bulb warning light also comes on at this point. On full beam - both side come on!
Have replaced both H7 bulbs - but get the same problem, have tried swapping the bulbs - just in case - but it works fine when fitted to the left side.
Have checked the fuses in the panel behind the light switch - these are all good...!
What next - I would welcome any advice / guidence.
Thank you,
Moderator/Founding Member
It is likely your multifunction switch on the steering column. The switch that does high and low bean, left and right signal as well as windshield wipers. I know that was the root cause when both my high beams stopped working.
If you search by my user name "MidLifeSolution", you will find a thread that covers replacing the switch. What the thread doesn't cover is removing the lower dash panel to get at the wiring harness to unplug and plug in the switch.
