1 - 20 of 30 Posts
Premium Member 2005 SLK55 AMG
Hi All
Yes to the header upgrade , I love mine best mod I had done , Are you keeping the centre box & rear cats.
Cheers
Andy
Just the headers will see what power I get; working on the intake, I ported the throttle body and shaft already; along with the elbow..... once everything is on I will get it tuned.
Hi All
I had headers + front cat removed & ECU flash this give me an extra 50 bhp.
Cheers
Andy
Don't forget to Thermotech wrap or have them ceramic coated. I wrapped mine while binging Netflix.
Proven performance results as well as a much lower under hood temp.
I debated on this one.... I like the bare look of the headers but my CLA45 downpipe is wrapped....
PITA so far, one off.... two more back nuts on the DS and then its on to new header installation...
Any suggestions on the back two bottom Passenger side nuts? Do I need to remove the starter?
Got the back bottom from the top with a long 10mm closed wrench, second to last from the bottom with a 10mm wrench
Discussion Starter #13
Headers are installed, fitment to the stock exhaust was a challenge, I used a tail pipe expander(broke 3 of them) to get the pipe round enough to slip a stainless coupler over it and the downpipe. The Downpipes were alittle awkward, and really need a flex fitting to work well. DS downpipe is longer than stock... also surprised there is not much give or spring in the exhaust, typically an exhaust is hung on rubber grommets or springs to allow some movement in the exhaust.... alittle worred about the stress on the exhaust studs.
Some sounds clips tomorrow
Registered 2006 SLK 55 AMG w/P30
I like it. I have the aft cat delete and SuperSprint X-pipe, but like your sound better. Record some exhaust sound under load if you can. What does your butt dyno say?
Hi All
Sound good , Whats your setup now ?
Cheers
Andy
Discussion Starter #17 (Edited)
Kleemann Midlegnth headers; 2ndry cats still in place and stock mufflers
Ported Intake elbow
Ported Throttle body and shaft
Tune coming... waiting on info
will build an intake this winter
Registered 05 SLK55 & 06 Kleemann 55K S8
Eurocharged did the tune on my first 55, I was quite happy with it and they are very reasonable. It took about an hour, they read my tune, sent it to the tuner, then installed it. They have a couple of remote tuners that are pretty good.
Discussion Starter #19
Just sent my file to Eurocharged also getting the TCU tune, it was a pretty good deal.
Discussion Starter #20
Had to throw some DEI plug wire insulators on due to the heat, the plastic covers were not liking it despite have the headers wrapped....
1 - 20 of 30 Posts
