1 - 9 of 9 Posts
Does anyone know how I might go about purchasing the wiring harness that connects to the left speed sensor? This would be the wire that goes between the car (blue connector) and the harness.
I went to change mine and it came apart in my hand and appears to have been previously spliced by the last owner. It apppears that each connector on the inside of the car should have two wires for each of the blue harnesses? Mine only has one each.
Any suggestion on how to get it out would be apperciated.
Sent from my SM-G970U1 using Tapatalk
Thanka for all the response. I actually have the speed sensor A 203 540 04 17. Im looking for the harnness that cconnects to it. Looks like it is kind of a pigtail from that part to the inside of the car. As you can see in pickture mini is all split and the wires to it were cut. It appears to run to the blue connectors seen in the first picture.
That blue connector on your first picture doesn't belong there - it's some kind of splice or tap. Maybe there was a previous repair there? Or somebody tried to add something?
1 - 9 of 9 Posts
