1 - 14 of 14 Posts
Bought a tower strut bar from UltraRacing. (Picture later) I have couple of questions though.
The fastening brackets are about 4mm thick, leaving in my opinion not enaugh threads on the original bolts. Can they be replaced?? (Hoping that JBanks has pictures of the suspension assembly)
How much torque should I use to tighten them??
No sorry, but I remember a thread on the same subject of bolt length.
Registered 2005 SLK350
Jeff is correct that there is a thread that discusses the special type of nut needed to secure the strut brace. Not sure if we came up with a source but I do remember a picture of the nut. I was part of that discussion so you may be able to search using my screen name.
The nuts are to be torqued to 26 Ft Lb (35 Nm).
Good luck.
I'll look into other type of nuts. Btw. here is a picture of the installation.
It makes the front a bit stiffer, reducing flexing in high speed cornering.
It seems like the nuts I need, are not available here in Europe.
Then, buy them in from wherever!
I think you will find they are the same as the BMW M3 struts - see this link to Tischer in the US that even gives you the part numbers!
Tischer BMW - OEM E46 M3 Front Strut Brace Kit!!! - E46Fanatics
Be careful with them as you will need to widen the existing holes in the plates which will need to be quite precise!
I believe for the purpose, the existing nuts are fine - ok the thread does not come all they through, but a good portion of the nut is 'working'.
Thanks for the link. Found a supplier for them in Sweden, but they charge double the price as Toughnutz.
Never had a problem in years with the stock bolts. The bolt length looks the same with Black Series model and strut brace.
I wonder if the Black Series uses a different nut - such as the shoulder nut, then the cars that do not have the strut bar. Unfortunately, no easy way to look up parts on the Black Series cars.
1 - 14 of 14 Posts
