1 - 20 of 28 Posts
Hello,
As SLC's are getting over 3 years old, I see a few for sale now under £20k.
Is it worth the upgrade from a R172?, apart from the revised styling, don't see much difference.
Must say the R172 looks more sporty too :laugh:
Appreciate any comments from those that have made the change.
Cheers
Registered 2011 SLK250
Depending on what Model Year SLK you refer, you may get upgraded 9 speed transmission, color instrument cluster, and of course, the newer infotainment system.
The engines of the SLC are also newer and more eco friendly.
You might also find SLC's still under warranty.
You should also take into consideration that, while you may find SLC's under 20k, they may lack many options that you could otherwise find on an SLK under 20k.
As you also said, and as a personal preference, I think the SLK looks more muscular, with the edgy shapes, rather than the curved shaped SLC.
As the SLC is a refresh/facelift, I would normally say go for it, but since, from design point of view, the SLK looks better, and most of the things found in the SLC can be found in the SLK, I would personally go with the SLK.
Thanks, so the SLK250d engine is different to the SLC250d engine?
Do you know the differences, assuming both have 9 speed Transmission.
SLK 250 BlueEFFICIENCY 2011- 1,796 cc (110 cu in) I4 turbo (M271 DE 18 LA) 204 PS (150 kW; 201 hp)@5500 310 N⋅m (229 lb⋅ft)@2000-4300
SLK 250 CDI BlueEFFICIENCY 2012- 2,143 cc (131 cu in) 16V I4 2-stage turbo (OM651 DE 22 LA) 204 PS (150 kW; 201 hp)@4200 500 N⋅m (369 lb⋅ft)@1600-1800
SLC 250d 4 cylinders, 2.1L turbodiesel 204 PS, 4,4 l/100 km, 114 g/km, 0–100 km/h in 6.6s, 245 km/h
250 7 speed
slc 250
9G-Tronic automatic gearbox, except for the 180 and 200 in which a manual 6-speed gearbox is standard,[17] although the automatic is available in option.
There probably is no 2016 slk 250d AND 2016 slc 250d... one or the other was made
Registered 2009 SLK200
The new SLC are now named 173 models .
Update : i was informed wrongly by a new SLC owner ( and some websites are showing the SLC as the new 173 model .??!!
So its still a 172 which i always thought it was but was informed wrongly .
no they are not :D they have r172 in their vin numbers and wdd
2016 slc WDD1724042F1344347
Plenty for sale on Autotrader, both with 9 Speed Auto Transmission.
only thing i can say is that in uk/overseas, as an example, the r171 came out 2004 but years for r171 are 2005-2011
same for r172...came out by you in 2011 but in usa 2012
or autotrader be wrong :D
if 9 speed cannot be slk...just saying
Less shipping time to UK? :D
or those selling in autotrader don't know if 2016, they have an slc and not an slk
title says 7 speed - just shows they do not know what it has
Mercedes-Benz SLK 2.1 SLK250d AMG Sport 7G-Tronic Plus (s/s) 2dr
This car has the later 9G Tiptronic gearbox in the new model, not the 7G normally in this model.
maybe it had trans issues and owner got a 9g as a replacement
Premium Member 2018 SLC43
The CarWow website has good SLK/SLC comparison Pictures & the a brief write up of the changes:
Details: https://www.carwow.co.uk/blog/mercedes-slc-vs-slk
Though I'm not sure the COMAND is that much better, though agree the 9G box is very slick..
Update : I was informed wrongly by a new SLC owner ( and some websites are showing the SLC as the new 173 model .??!!
So its still a 172 which I always thought it was but was informed wrongly .
My 2018 SLC has a WDD1724662F~~~ vin number as well..!!
But if You Google R173 it does comes up with loads of SLC pictures..!! :|
which look exactly the same as the car is the same and those 173 links are uploaded by people that haven't a clue :D
1 - 20 of 28 Posts
