1 - 9 of 9 Posts
Founding Member 2006
Please update your location in your profile as it helps the members answer your questions which usually are based on that information if you haven’t.
Follow exactly to update: ‘Usercp’ at the top of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘location’ . Your profile is NOT updated in your ‘personal garage’.
Location also please
2017 SLC43
If I understand the question correctly, if you start the car from warm, it changes up at a certain number of revs from 1-2, then 3-4 and so on.
But when it's cold, it makes that 3-4 change at a different engine speed? It holds onto 3rd gear for longer when it's cold?
I'd say that's normal. It helps warm the engine up quicker and that brings the heater on faster and makes the car more fuel efficient overall as a hot engine is for economical than a cold one.
2000 SLK320
Hey guys my 2014 slk 200 auto gearbox is slow at up shifting into 4th on a cold start, is that normal? Thanks.
Morning SG, my 170 stays in 3rd to get the cat up to temp quicker then changes normally it should explain it in the glove box manual.
Regards Stuart.
Discussion Starter · #7 ·
Thanks for the immediate reply guys, if I up shift manually into 4th on a cold start at any rpm the gear change still is not smooth. Is that because the gearbox is cold? It's as if your driving an ordinary manual car and change gear without leaving the throttle.
Personally I let the car do what IT wants for it knows better than me, thus allow time & be patiently happy to trundle for a mile or so in lower gears before nicely warmed & can change up. It's called engineering sympathy & respect.
1 - 9 of 9 Posts
