2001 slk-320, can anyone pinpoint the location of the fuse powering the changer. the connector reads 0 vdc now ,no lights on the changer.
thanks for any help.
dale
Dale,
We’d like you to post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already. http://www.slkworld.com/new-members-introduce-yourself-here/
you locate the fuse boxes? should be a diagram on which fuse is what
fuse cd changer location in 2001 sl
since there is no listing separate for the changer I would assume the changer is powered from the radio fuse. close check of the dc power cable shows there is 12+ volts is at the power cable plug for the changer. so I guess power is not problem. checked the fiber cable from the radio to where it plugs into the changer, looks ok passes lazer light ok. Put it all together and nothing, no life from the changer,eject etc and radio reads no changer installed. I noticed while the radio was out a second fiber cable with a rubber boot taped to the back wall of the dash. any idea what that second fiber is for.?
do you know the pin out of the cd cable for the changer? 3 pin with blue.black and brown wires.
be grateful for any help on this
dale
Our experts will reply when they check in. In the meantime, please post a new member introduction thread.
