Fuse Access
1179 Views 4 Replies 4 Participants Last post by  jbanks15
I want to access the fuses located in the trunk/boot and would appreciate any tips (other than removing the two plastic fasteners above the spare wheel) for removing the liner/panel that the fuses are located behind. I did a search but found nothing relevant.
You can get to them just by pulling the "carpet" out from it's position, the rear part which covers the fuses is held in place by the side panels...
Try this link: http://www.slkworld.com/64661-post2.html
If you need photos, check out Durkatlon's thread on the custom wire loom/harness for aftermarket rear tail lights.
you guys are wayyyy too late :D
