Fuel injector signal..
847 Views 4 Replies 2 Participants Last post by  Mantist
I want to know what the signal (waveform) is like on the fuel injector. I also would like to know where the signals originate. Thanks.
It comes from the Motronic ECU. I haven't put the scope on it, but it's basically a PWM square wave. {edit} The injectors receive constant +12V power when the key is on, and the Motronic opens and closes the ground, generating the square wave pattern.
Thankyou efair!
Where is the Motronic ECU? Pinouts for each injectors?
I'm not sure, what's your VIN and I'll look it up. What kind of problem are you trying to solve BTW?
I found a solution. No need to look it up. Thanks.
I am trying to experiment the effect on mpg with a rolling fuel shut-off.
