Fuel gauge problem
768 Views 2 Replies 2 Participants Last post by  jbanks15
Sometimes the gauge show zero and no orange light (like no signal received),
most of the times it show erratic reading, sometimes low fuel (reserve light).
When I fill up the tank still about 1mm to go to indicate full.
Any ideas before I go to the shop?
Thanks!
First please update your location and vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
See less See more
http://www.slkworld.com/general-dis...ock-sluggishness-hesitation-top-tier-gas.html
Techron Concentrate Plus Fuel System Cleaner
Exclusive Synthetic Formula. Whether protecting your new valuable investment, restoring your used car to its original performance, or simply keeping your engine as clean as it can be, Techron Concentrate Plus delivers a number of unsurpassed benefits and one unique benefit - the ability to eliminate faulty fuel gauge readings. Techron Concentrate Plus can help:
RESTORE
• Fuel efficiency
Operation of broken fuel gauge sensors
• Lost power and improve drivability
CLEAN
Sulfur corrosion from fuel gauge sensors
• Combustion chambers, intake valves, and ports
PREVENT
• Engine knocks and pings, spark plug fouling and cold start issues
Harmful sulfur components from attacking sensitive electronic fuel sending units
PROTECT
Fuel gauge from malfunctioning by coating all metal surfaces of the car's fuel system.
See less See more
