1 - 12 of 12 Posts
Registered 1998 SLK230
Hello a few years ago I tried to jumpstart my friends car and after that I noticed my fuel gauge stopped working. It usually goes past full and turns until it is touching the other gauge. Some other times it will just randomly move around I just use the odometer to keep track now but I really want to fix it. Any ideas?
You can use what you want :D
Members have posted in the thread their success (or not) with a bottle of techron
Could I just use sea foam I have been told to use that before to clean up the engine.
Never used it (but thought about it). I've read some good reviews about seafoam and a lot of not-so-good threads about it.
Techron is the rage here {ie: this forum; if you can get it). I don't because it's not generally available here.
Alternatives (for us Northerners) http://www.optimaforums.com/forum/6-optima-engine-technical-discussion/12973-chevron-techron-substitute-canadians.html
UPDATE: After about two years the car final gave me a code. The code is P0460 Fuel Level Sensor A Circuit. I am going to see what I can do about the float and the circuit if anyone could give me any info on the sensor.
This may sound a bit weird but when my fuel gauge stopped working I traced it back to the dash wiring harness not being clipped back in properly after changing dash bulbs.
Have you been behind the dash recently ???
Hallo,
Exact the same happened to me this afternoon. Replaced bulbs in the cluster and the fuel gauge was at 0.
The lock of the left connector did not "grabbed" the receptacle from the cluster. Reconnected, all normal.
GRZ Eric.
The codes don't lie. Replace fuel level sensor.
A1705420317 SENDER UNIT
Replaced by: A 170 542 07 17 -
A1705420717 SENDER UNIT
Replaced by: A 170 542 10 17 -
A1705421017
Replaced by: A 170 542 14 17
So it looks as though part # A 170 542 14 17 which is $207.50 on mercedespartscenter.com:frown:
1 - 12 of 12 Posts
