1 - 20 of 253 Posts
jb edit: fyi this thread was written 10 years ago :D Techron injector cleaner also is great besides their system cleaner.
Tuesday evening, leaving enclosed parking garage at work. I start my 09 55 amg as usual. (background: baby will be 1 yr old 5/22/09. 17600 miles). Since I clean my car twice a day and know even a mosquito has landed and left little bitty feet marks, I was surprised to hear a tick, tick, tick sound as soon as I started the car. Hmmm, I say to meself, that is not normal. Whether in gear at idle or driving slowly I heard it. I also noticed something I did not notice before. Hesitation on acceleration. I take off to Mercedes and of course, once car is warm no sound, so I leave it for them to check out with engine cold in the morning.
I check the next day and they say I have a slight case of engine knock. Engine knock? I use Shell 93 which is in the top tier of gasolines:
What is TOP TIER Gasoline designation?
In 2004, BMW, General Motors, Honda and Toyota established the TOP TIER program, which established criteria for detergency levels in Gasoline higher than those currently set by the U.S. Environmental Protection Agency (EPA). This standard established requirements for the design of Gasolines that keep engine parts cleaner than lower-quality Gasolines by providing reduced fuel-related deposits, resulting in better engine performance.
Top Tier Gasoline Retailers:
TOP TIER Detergent Gasoline Retailers
Gasoline retailers must meet the high TOP TIER standards with all grades of gasoline to be approved by the automakers as providing TOP TIER Detergent Gasoline.
In addition, all gasoline outlets carrying the brand of the approved retailer must meet the TOP TIER standards.
Additional gasoline retailers are added to the TOP TIER list as they meet the standards. The retailers known to be on the TOP TIER list are shown below.
Click on the YouTube video title bar to play
TOP TIER Gasoline Retailers:
https://www.toptiergas.com/licensed-brands/
MB says, well, do you pamper it? I say, ‘you’re joking right? I have a lead foot! I do 100 on the interstate. I attempt to beat all challengers off the line.’ So I say, What’s the fix? They say, Chevron Techron Concentrate. I say, an additive? You’re saying the fix for ping/knocking/hesitation on a $70,000 09 amg with 17000 miles is an additive?!!! They say yup!
Now in my 47 years of driving (age 65) I have never, ever used an additive. Don’t believe in em. Waste of money in my opinion. I remember those stp commercials!
MB says that is what they recommend for this issue with amgs:
Although Techron Concentrate is not precisely the same formulation as used in our gasolines, its formulation is derived from the same unsurpassed polyether amine chemistry. Roughly speaking, it is about 10 times stronger than the formulation added to our retail gasolines. If you use a Chevron-family gasoline (Texaco and Chevron with Techron) regularly, you shouldn't need to use a concentrate unless you have a particularly sensitive vehicle or use your vehicle in very severe conditions.
So I have half a tank of gas left. I go to autozone and pick up:
Techron Concentrate Plus Fuel System Cleaner/Injector Cleaner
Exclusive Synthetic Formula. Whether protecting your new valuable investment, restoring your used car to its original performance, or simply keeping your engine as clean as it can be, Techron Concentrate Plus delivers a number of unsurpassed benefits and one unique benefit - the ability to eliminate faulty fuel gauge readings. Techron Concentrate Plus can help:
RESTORE
• Fuel efficiency
• Operation of broken fuel gauge sensors
• Lost power and improve drivability
CLEAN
• Sulfur corrosion from fuel gauge sensors
• Combustion chambers, intake valves, and ports
PREVENT
• Engine knocks and pings, spark plug fouling and cold start issues
• Harmful sulfur components from attacking sensitive electronic fuel sending units
PROTECT
• Fuel gauge from malfunctioning by coating all metal surfaces of the car's fuel system.
Now I don’t want this to sound like a commercial but I poured it in my half a tankful of gasoline and drove to the nearest Chevron station approximately 3 miles away to fill up. (It comes in 2 sizes for 12 gallon and 20 gallon tanks. They recommend a ¾ empty tank).
The car had no hesitation!!! This was before filling it up! I kid you not! The next morning, I listened intently for any tick or ping or hesitation. None! I leave home at 530 am so the streets are quiet and you know how you can sometimes hear engine noise when things are quiet reverberating from the houses? Nada! I wait until the car warms up ( the oil temp gets to 80c and stops blinking) and I punch it! WHOA MAMA!
When I left work yesterday (enclosed parking garage), engine cold, I hold my breath as I start the engine. Whew, nothing but that sweet, throaty sound.
Sorry, for this long winded tirade, but I am convinced this product solved this issue and highly recommend it. It can be used every 3000 miles. Would like to hear from any other secret Chevron Techron Concentrate users.
Have a nice Weekend!
Founding Member #2
Thanks for the narrative jbanks. 95% of the time I use Chevron gasoline but this is good to keep in mind.
D
Guest
Hi Jeff mate, my personal view is fairly limited here, i was taught by MB never to use/recommend additives over and above what is already in the fuel because you can get too much of a good thing going, i don't design fuels or additives so i can't comment on the technical side too much but i can see both points.
Extra additives = cleaner engine / extra additives = engine attack.
Legin should know
I too know nothing... or I should say.. very little about fuel additives.
I do know oil additives are snake oil. But that's apples, this is oranges.
I would think that with your attention to detail you'll be letting us know if using it creates a long term issues.
My questions are.
Did they recommend you use it once? only when you hear it ping? or continually until the day you and the car part?
Did MB recommend this? or the MB dealer? ( I once had a lengthy discussion with a VW dealer over their practices of using an oil additive during regular services. Turns out the dealer was part owner of the company that was supplying the oil additive to them.)
Thanks all for the input.
No, they said you could use it every 3000 miles if desired and all the reviews I have read were all positive. they did not mention about only when pinging, but if the acceleration boost is an indication of whatever was taking place now being resolved I can see me using it every 3000 miles for the less than $10 it costs.
The mb dealer says that they recommend that to all who drive 'amgs' but other than this fix, there is none.
tslick, do you know what kind of additive? maybe it is written on your service order. just want to know what brand they use. thanks
Thanks, Jbanks15.I just realized recently that my engine seems to give a slight knocking noise when I first start it up in the morning. I think I'm gonna try it over the weekend and see how well it goes for me.
Let us know. I've been cautioned, that just like alcohol, tobacco and illegal drugs, if you overdo, your car will get hooked and need a fix more than it should or need.
No P/N for the additive, has a typical description of the service that includes "then a powerful fuel system cleaner is added to the fuel tank.....", funny. The fuel kit P/N is 210-2 and $43.00 material. Sounds like an internal P/N but who knows. Maybe listed in startekinfo.
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
Discussion Starter #13
Thanks tslick. So there we have it. MB recommends Techron Concentrate. walmart sells the 12 fl oz size for $6.99.
Awesome! So $43 for $10 OTC meds. Sounds about right for the stealership :tu: Why am I not surprised? When I owned an Acura and had it serviced for regular oil change at the dealership, they used to put in a fuel system cleaner every oil change. First couple times, they snuck it by and I never really paid attention to my invoice, just thought it was inflation. They'd charge me like $20 for it (easy $$) and it was the same thing I could buy for $7 at your local parts store. Finally, I started putting it in myself and telling them not to do it.
I think I'll go buy a couple of these and water both the horses R)
Founding Member #2
Thanks for the money-saving info
Startek recommends Techron Concentrate Plus Fuel System Cleaner (588 ml, 20 fl oz container). Look at page 15.
Thank you both Jbanks and Tslick for good information.
This site saves its members time and money, well worth the support by being a contributing/paying member (shameless plug :D)
I think I'll stick with Chevron gasoline (as recommended by service advisor a while ago in 1996 when I had the E300).
Discussion Starter #18 (Edited)
Check pep boy's memorial day flyer. buy 1, get 1 free instantly at checkout:
techron fuel system cleaner 12 oz, reg $7.99. limit 2 offers.
Founding Member #2
I tried this yesterday, mainly because the engine has 22,200+ miles on the clock and noted some very mild ticking sound from the left bank of the engine (driver side for LHD). The fuel gauge indicated 1/4 (roughly 4.6 gal); stopped at local Chevron station and poured in the Techron Concentrate Plus (treats up to 12 gallons) followed by 7.5 gal of Premium Unleaded gasoline, and drove around.
I must say there is a noticeable difference when you depress the accelerator pedal at a rapid rate. The car feels like everything was slippery and smooth, engine exhaust sounded like everything wasn't a problem, like it was saying, "give me all you've got, I can handle it." The mild ticking sound disappeared. I figure/guess it was some mild carbon deposit on one of the valves.
Just wanted to post my experience.
Discussion Starter #20
eddy, your 08 has 22k and my 09 has 23k. lol!!!
1 - 20 of 253 Posts
