1 - 20 of 20 Posts
After overnight rain my battery died. I jump started it in morning and noticed that fog lights were on even without turning the switch on. I turned the car off and fog lights were still on. What are usual area of short circuit in car?
is the light switch pulled out to engage fogs inadvertently?
but is it pulled out or pushed in? that usually controls the fogs
dang! there went that idea.
Definitely wet PSE. Read some of the threads on here for more details. But basically you'll need to pull it out, dry it out, and then put it back in. Make sure you clean out your drains and seal up any leaks to prevent it from getting wet again.
I removed PSE pump from car. i will wait till weekend and see if battery dies
Fog lights stay on after you get out of the car dont they?
(at least mine do) and then shut off like a few minutes later, but stay on if I leave the door open. May be a door sensor or something similar too.
fog and running lights not going off
I have the same problem. Fog and parking lights do not go off unless battery is disconnected. What did you finally end up doing. My PSE was completely dry. I live in New Mexico.
Thank You.
I took the bottem off of the PSE and found that the relay closest to the outside middle was stuck closed. I put some matchbook cardboard between the points and now all works well but no fog lights but who needs fog lights in the high desert.
Thank you for getting back.
Slade
Slade
First please update your location and vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
2001 slk230 amg front bumper
i change my front gumper from a stock bumper to the amg bumper. The problem is the original fog lihts wont fit the new amg bumper. Does any one know what kind of fog lights go with this bumper. i bought 3 kind of fog light that look like it fits but it dont....thank you
Welcome
post an intro
update your profile, model n year n location
then we can answer your question when we know what you are driving
this thread is 6 years old
you might want to post your question in the appropriate generation section
First please update your location and vehicle (Put Looking!)(year?: 1996-2018, model?: 32, 43, 200, 230, 250, 280, 300, 320, 350, 55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section. Click this: New Members Introduce Yourself Here - Mercedes Benz SLK Forum
On a smartphone: http://www.slkworld.com/new-members-introduce-yourself-here/330737-how-update-your-profile-post-intro-smartphone.html
1 - 20 of 20 Posts
