1 - 20 of 26 Posts
1999 SLK230
Hi all, 99 R170,on Sunday I went to carwash they did undercarriage was, outside I was drying the access water, I noticed the fog lights and the parking lights stayed on, I tried to turn /push the light switch on of, didnt help, I had to disconnect the battery so it wont drain, yesterday, the fog lights were not on when I turn the ignition off I noticed only passanger side parking lamp and the tail lamp staying on, so still disconnecting the battery, is it coincident that the relay is stuck? if so where is parking light relay, is it in the K40 module or where? I think it has nothing to do with the fuses, because with the switch lights works, I am thinking its a relay related, any ideas? i would appreciate if anyone have a solution, its PITA to disconnect the battery everywhere. Thank you all in advance
Ardo
1997 SLK230K
Well hopefully someone will recognise the symptoms but if nothing comes up maybe see if you can get hold of a module from a breakers.
1999 SLK230
Discussion Starter · #5 ·
Hi Rofa, again thank you for your response, who are breakers?
1997 SLK230K
A car dismantler....... It's just that these units are expensive new and unless you can positively identify the cause, a cheap second hand unit might be a quick way to identify the problem. Or take the car to a MB specialist.
There are no separate relays for these lights, as said Lighting Module is 99% certain to be the culprit ;)
HTH :)
Reactions: M4rCu5 and Rofa
1999 SLK230
Discussion Starter · #9 ·
Good morning, thank you for your suggestion, where is the location of this module and anyway you could guide me to a picture of the module?
1999 SLK230
Discussion Starter · #11 ·
Vying for the #1 position :eek: .. I just bought another one for the spares department :p
Hi would you happen to have the part number for the lighting module, I am having problem finding one, I will try searching with part number, also would be great if you have a picture of it
1999 SLK230
Discussion Starter · #13 ·
2001 SLK200K/2001 SLK320
For both of my Post-FL's (RHD) the p/n is 170 545 0504 - yours will be a different p/n based on (a) you have a LHD and (b) yours is a Pre-FL
1 - 20 of 26 Posts
