2008 SLK55 AMG
Receipt of the package
To try to see!
Cut the original line with a 1.6mm disc to promote rigidity during operation
The cutout must be 5 cm less than the X-Pipe for mounting
Clean the surfaces to be laid
A blank test
I opted for stainless steel collars less expensive than the sleeves so you have to make slits
Put the collars in place
The diameter of the necklace
Assembly, clean the end caps on the cat side
Put the X-Pipe in place with new 8.8 screws
Line up the collars but do not tighten them
The result
Installation of silencers:
Put paste on the fittings to prevent water leakage
Install one silencer then the other and remove the excess paste
Tighten the flanges on the cat's side, fit the silenblocs of the silencers and fit the stab bars
Adjusting the flange spacing
The result
Enjoy
